TOPAZ will add Extension automatically as the calls
come in from the PABX unit, therefore all extensions used by
the PABX can go thru to TOPAZ.
To exclude calls to/from a extensions from being
added to the TRAN file, keep the following in mind:
ALSO SEE: My extension/calls does not get imported in TOPAZ.
If you delete a extension from TOPAZ and the PABX Unit
sends off a call for that extension it will add the Extension
to the Extension table.
If you remove the extension on the PABX Unit
and then delete it in TOPAZ -> DATA -> EXTENSION and you do
a "Update TRX ..." it will add the Extension to the Extension
table, since there are still calls in the TRAN file for that
extension.
