Error: "Invalid BLOB handle in record buffer"
Postby Belinda Frick » Thu Nov 25, 2010 12:53 pm
This might be a problem with your Master.DB file.
This file contains all your telephone numbers.
Try the following:
Re-index the Master.DB file.
ALSO SEE: How do I reindex a database file?
If this does not work you will have to create a blank
Master.DB file.
There are no export facillity for numbers in TOPAZ.
You can print a list of all the numbers and descriptions:
In TOPAZ -> DATA -> NUMBERS -> Click on Listing.
To create a blank Master file:
- Close TOPAZ,
- copy the Master.* files from the CD
- remove the read-only attributes.
ALSO SEE: I get an error "index out of date."
Now you have a blank Master file. As calls are made /
received the telephone numbers will be added to TOPAZ.
To add the Person / Company ... go to -> DATA -> NUMBERS
You can import all the number from a text file.
ALSO SEE: How to import telephone numbers into Topaz.
This document is incomplete!
