The following features have been added:
On the Setup menu you can now select if the person, company, or
both entries show be asked for on the Reference popup screen.
The following has been changed:
The 10 second delay for poping the reference window up, has been
changed to 1 minute. This will allow easier access to type in references.
The Callmonitor.INI file is now loaded and saved to the same folder
where the callmonitor resides.
