TOPAZ Standard Report: Standard vs Routing
Postby Belinda Frick » Thu Nov 25, 2010 1:11 pm
TOPAZ -> Reports -> Standard Reports
The Standard vs Routing report shows the savings made when using a router.
Report columns include:
Duration: Call Duration
Carrier : Line Call was made on
Actual : Cost according to actual router rate setup in TOPAZ
Standard: Call cost if call was made with Telkom rates
Router : Call cost according to the rate you selected in the report setup.
The Total bar:
The saving value is the saving made using the rate your selected.
(Standard minus Routing Cost)
