Yes, simply copy your file (with a .pip
extension) to the path in the PIP directory:
See path => SETUP => PROPERTIES => PABX
(PABX File Update)
This will normally be:
"C:\Program Files\Datatex\pabx3\pabx.pip"
Then change the "pabx.pip" to "*.pip".
Now the import will include your .pip
files.
ALSO SEE:
Format of a PIP file
How do I import extra PIP files into Topaz?
