How do I use DTP and PABX3 together on one PC?
Postby Belinda Frick » Thu Nov 25, 2010 1:24 pm
PABX3 changes
Go to the Network tab on the PABX3 configuration.
Change "Listen on port" to 25100.
Click on the "Save" button to save the configuration.
DTP changes
Make sure you are using DTP version 1.2.6.33 or later.
Download the install and update, available on the website:
http://www.datatex.co.za/download/emera ... .2.2.0.exe
http://www.datatex.co.za/download/emera ... .2.8.4.exe
Go to the "Settings" section of the DTP configuration.
Enter the number of digit for your extensions.
Go to the "Topaz" section of the DTP configuration.
Clear "SMDR Enabled" - untick this option.
Make sure "Network enable" is ticked.
Click on the "OK" button to save the configuration.
TOPAZ:
For reference to barring on the Panasonic TDA, DTP is hardcoded
to run on port 25001. You need to setup this in TOPAZ under
SETUP -> NETWORK/FRONT OFFICE, PABX3 Interface, set the port
to 25001 and the IP DTP is running on.
