How do i delete call data in TOPAZ?
Postby Belinda Frick » Fri Nov 26, 2010 10:34 am
1. If you want to delete old call data:
Login to Topaz as Admin.
Click on "Setup -> Properties -> Transactions".
There will be a button labelled "Purge prior to".
This will purge all calls before the specified date.
You will be prompted to choose a date.
If you do not have this button, please upgrade
to the latest TOPAZ version.
2. If you feel that TOPAZ is taking up too
much diskspace:
You can delete the TMPTOPAZ folder. This folder
can be deleted once TOPAZ is cloded. (It will
be recreated as this is only a folder with
temporary files)
C:\TmpTopaz
