Printing TOPAZ reports
Postby Belinda Frick » Fri Nov 26, 2010 10:43 am
Firstly, setup all the reports you need.
Select one report to print:
Use one of the following options:
REPORTS -> STANDARD / MANAGEMENT / EXCEPTION / CUSTOM
This will show you the details of the report settings.
Select your report and then click on the print button.
Use the TOPAZ Menu at the top of your screen.
Third from the left it reads, CUSTOM REPORTS.
If you click on this it will list all your Custom report names.
When you select the report name, it will send it immediately
to the printer.
Fourth from the left it reads, EXCEPTION REPORTS.
Daily, weekly, monthly printing of reports:
Use the batch report setup.
ALSO SEE: How do I setup a batch report?
