When I run the rates update/TOPAZ upgrade, neither upgrades
Postby Belinda Frick » Fri Nov 26, 2010 10:48 am
Close the Master TOPAZ and all Client TOPAZs.
Make sure no TOPAZ is running in the back-round.
The TOPAZ upgrade uses the default filepaths.
Earlier versions of TOPAZ used the filepath,
C:\Program Files\Datatex\Topaz Telephone Management
The current default path is,
Make sure of the file path when doing an upgrade.
If you moved or copied TOPAZ, make sure that the
files are not read-only.
