New Features:
The new Ring Time Analysis report shows each hour of the day at the top
of the report and lists the extensions down the side. It lists the total number
of calls for each hour, per extension.
Display the reference on the Detail with Summary report in the
account code column. This is a setting on Filters and Defaults.
(Departmental Analysis still prints the account codes)
A fixed cost can now be given to each extention for billing purposes.
It will only be printed on the Billing Invoice and will override the default
value in the Setup of Topaz.
Issues Resolved :
If the Budget Type has no value when saved, it will default
to an "E" (for extensions) now.
Ensure that the "Group By" field on the Custom Reports can not be
left blank.
Ensure that the Detailed report with custom field can be printed
via the batch reports.
When your Locale is set to "Afrikaans", the Telkom Reports,
Cellrouter Analysis, Dept Analysis, and Billing generates an Error:
"Invalid Type".
Test Batch Report now prints to the scheduled printer and not
to the default printer.
Enqueries are now read-only.
Company Name is now on the Telkom Summary and Detail.
Data paths not ending with a "\" would generate errors in some cases.
