What is new in Topaz 1.7.0.5
Postby Belinda Frick » Fri Nov 26, 2010 11:03 am
New Features:
Company Cost Analysis now also displays the extensions and user names.
Company Cost Analysis now displays the Company Name at the top of the report.
The Company Cost Analysis format can now be used on the Custom report screen.
The batch reports have an option Auto Advance, that allows Topaz to adjust the
Custom report's "Between dates" values. The dates will be advanced after the report has
been printed. (e.g. [from 7-Jan-2004 to 6-Feb-2004] will be advanced to
[from 7-Feb-2004 to 6-Mar-2004])
A popup window will ask for the From and To dates of a custom report, that is printed
from the Custom Report menu, if it has been configured to use the "Between Dates".
Issues Resolved
Company Cost Analysis has been adjusted to allow the extensions to be displayed
in between the section and the section totals.
When the Company Cost Analysis report format is used on the Custom reports screen,
the "Maximum records" and "Order by" options are not listed, since it can't effect
this report.
