Setup in TOPAZ:
The fixed billing in setup must have a value to ensure that the fixed
billing on the extensions screen is working.
This fixed fee will be added to the Billing total after the calls have
been totaled.
Setup your "default" fixed fee by extension in TOPAZ under
[Setup -> Properties -> Billing -> Fixed Cost per extension]
For individual fixed fee by extension:
In TOPAZ under [Data -> Extensions -> Fixed Billing],
Enter fixed billing fee for that extension, plus description.
This fee will overide the the fixed billing under
Billing Invoice:
In TOPAZ under [Billings -> Master Billings]
Bill on User:
When a report is generated by user, the description under [Setup -> Billing]
will be used. All the fixed fees for extensions for that user will be totalled.
Bill on Extension
When a report is generated by extension, the description on the
[Data -> Extensions] will be used.
