Error when running PABX3
Postby Belinda Frick » Fri Nov 26, 2010 11:29 am
Close TOPAZ and run only PABX3.
PABX3:
Make sure that your filepaths exist.
Re-select the dll by navigating to the location,
[OPTIONS -> FILE PATH -> PABX DLL -> ]
C:\Program Files\Datatex\PABX3\profiles\lib\
Enter the pip file location,
[OPTIONS -> FILE PATH -> PIP FILE -> ]
C:\Program Files\Datatex\PABX3\pabx.pip
Once the error is sorted out, open TOPAZ.
TOPAZ:
Make sure the pabx.pip filepath is selected in TOPAZ
under [SETUP -> PROPERTIES -> PABX -> Pabx file update ->]
