BDE Install failure
BDE Install failure
Postby Belinda Frick » Mon Nov 29, 2010 10:51 am
Something is preventing you from installing BDE. This could be
access rights or Windows files that are damaged or missing.
If you have anti-virus software running, try the following:
if you are on a network, disconnect the PC from the network
and disable the anti-virus software.
else allow installation of BDE if using Windows XP.
Also allow TOPAZ and PABX3 in the firewall.
