Make sure you have the lastest rates update!
ALSO SEE: Topaz per second rates for Botswana.
Login to Topaz with Admin.
NOTE!You will need to know which lines your routers are on and which routers are on
which lines.
Goto [Rates -> Routing Table]
For a Mascom router you enter
71 LINE No CELLROUTERSAME 72 LINE No CELLROUTERORA
For a Orange router you enter
71 LINE No CELLROUTERMAS 72 LINE No CELLROUTERSAME
In 2006 MasCom added the prefix 74.
TOPAZ rates tables must be adjusted for this - 20070109!
