What is new in Topaz 1.7.0.9?
Postby Belinda Frick » Mon Nov 29, 2010 11:05 am
!!NOTE!! From this version of Topaz you will require version 1.7.0.11 of Callmonitor for
Callmonitor to work correctly.
New Features
Callmonitor Automatically finds Topaz on the network and configures themselves
with the locations.
Topaz Automatically configures Onyx and Onyx+ when they start-up.
Topaz configures Onyx and Onyx+ extensions automatically for network communication.
Topaz configures Onyx+ lines automatically for network communication.
If Onyx or Onyx+ notifies Topaz for Updates and Amethyst communication is
disabled, Topaz will Enable it.
Callmonitor can run on a different port as the default 25003.
Multiple Callmonitors can run on the same server (Terminal Server), each with a
different port.
Updated the Show CLI function to also work with the new Callmonitor.
If the user list is blank after Callmonitor has started up, it will request
the list from Topaz every minute until it receives it.
Changes:
Numbers in the Standard output format has been fixed to a length of 15 chars.
There is now a shortcut key for close on the messages screen.
There is now a normal windows close button in the top right screen, but this will
just minimize Callmonitor.
The Userlist is now sorted and unique.
