When using Topaz to export the data to the 3rd party product Jade (Not Datatex's Jade).
Enable the export facility in Topaz ( Setup -> Properties -> Network and FrontOffice)
Select the STANDARD Format.
Ensure the correct export path is entered.
Go to the DATA -> Extensions and tick the "Billing" option for each extension that
has to be exported.
Whenever a call comes through from PABX3, it will be sent to Topaz and then exported to
the file that Jade can import.
Example of standard output string:
Default location: C:\tmptopaz\TPZFO.txt
T:7005 6383166 1.39 12-07-2006 07:58:55
T:7005 0926461226311 1.88 12-07-2006 08:21:01
In this example:
"7005" is the extension
"6383166" is the telephone number
"1.39" is the cost allocated to the call according to your option in
TOPAZ -> SETUP -> PROPERTIES -> NETWORK & FRONT OFFICE,
Enable local front office option.
The "COST" is the Telkom cost, including VAT.
The "PRICE" is the billing price.
The "BOTH" option is the "COST" and "PRICE" added to one another.
"12-07-2006" is the date the call was made.
"07:58:55" is the time that the call was made.
