Access violation when re-costing
Postby Belinda Frick » Mon Nov 29, 2010 11:27 am
This could be a faulty costing value on the TRAN file.
View a report to check the costing values.
Try the following:
Close TOPAZ and open TOPAZ.
Check if there are any open errors. Fix these errors.
Check if there are any errors in the TOPAZ log file. Fix these errors.
Once all these errors is sorted out, try doing the re-cost again.
