New Features
Callmonitor will read the reference file every 24 hour.
Display when the next re-read of the reference file will take place.
Force reference file update by clicking the "Refresh reference File" button.
Enter the account codes on your configuration screen, that you want to receive
reference popups for. Callmonitor will configure the account codes with Topaz.
Hide the account codes unless you enter an already configured code.
Callmonitor supports a second reference dropdown now. It has it's own reference
file. Configure under the configuration screen.
If the second reference is used, concatenate the two references before sending to
Topaz.
New CLI popup Skin
New Reference popup skin
Issues resolved
When the Topaz IP was found after a broadcast, it would not display
it in the configuration screen.
