How do I exclude my VOIP calls from the TOPAZ billing?
Postby Belinda Frick » Mon Nov 29, 2010 3:26 pm
If the VOIP uses a line number, then you can set the
line up as an internal line to exclude the costing and
still see the calls in TOPAZ.
ALSO SEE: Tie-line
If the VOIP is set on extensions, you can exclude these
extension from being loaded into TOPAZ
ALSO SEE: My extension/calls does not get imported in TOPAZ.
