SS40 Modem buffer: sending the same data file
Postby Belinda Frick » Tue Nov 30, 2010 9:58 am
If the modem buffer cannot handle the data that you want to
buffer and send, the buffer capacity is reached and therefore
will not log any more calls.
Solution:
You need to dump the data and reset the buffer.
Suggestion:
To prevent this from happening again, set the modem up to dial
in more times per day (less data to transfer at a time).
