UTMS buffer: No call data in VT100
Postby Belinda Frick » Tue Nov 30, 2010 10:18 am
The default baudrate is 9600. Once you have connected it,
change it to the rate of your PABX unit.
VT100 -> type in "SP " followed by the baud rate that your
PABX unit is sending the data.
If the baudrate of the PC and the PABX unit does not match,
then you cannot communicate with the buffer.
Try the following:
Reset the buffer.
In PABX3 -> TOOLS -> VT100, type in "SP " followed by the
baud rate of the PABX unit.
To test the buffer, you need the buffer test program:
  1. http://www.suesound.co.za -> downloads, "Communication Software", Buffer tester.
  2. TOPAZ CD (1.7.5.4 or newer) -> Utils, "BufTest_2_05.exe".
  3. Download and unrar, password is 'datatex':
    BufTest_2_50-password.rar
You can use this program to set the baud rate.
Under investigation!
