How do I retrieve my "archived" data?
Postby Belinda Frick » Tue Nov 30, 2010 10:23 am
How you retrieve the data depends on what backup method you use.
Methods:
archieve.exe
How do I ARCHIVE pipe files in TOPAZ
Files to backup
How and what to backup
TOPAZ Centre
See section "How To Backup:" in How do I setup TOPAZ Centre?
Retrieving data:
archieve.exe
Import the file topaz.all. Remember this could be a very big
file and the import can take quite a while.
How do I import extra PIP files into Topaz?
Files to backup
PIP file folder
Import the *.pip file from where your backed it up.
Rawdata files
Import the raw*.txt file from where your backed it up.
How do I import rawdata.txt into Topaz?
TOPAZ Centre
See section "How To Access Data:" in How do I setup TOPAZ Centre?
