Required:
PABX3 version 3.3.3.0
Available:
On the internet
www.datatex.co.za -> downloads -> upgrades,
select "tpz-pabx3-update-3_3_2_2.exe"
The TOPAZ CD 1.7.5.4 or newer
In the updates folder.
The prefix value.
Example:
For this example the telephone number is preceeded by a "+".
The plugin rule setup below will remove this value from the
telephone number and replace it with "00".
In most countries "00" is used to dial an international number.
For costing purposes the telephone number must have the correct
international dialing code for the country from where the call
is made.
Procedure for this example:
PABX3 -> OPTIONS -> PLUGIN RULES
Settings:
COLUMN: NUMBER
CHECK METHOD: STARTS
CHECK VALUE: +
REPLACE VALUE: 00
STOP CHECKING RULES: please tick this option
ALSO SEE: How to setup a plugin rule.
