Required:
TOPAZ 1.7.5.4
Call Monitor 1.7.5.5
Upgrade available:
TOPAZ 1.7.5.4: www.datatex.co.za -> downloads -> software upgrades -> topaz
Call Monitor 1.7.5.5: www.datatex.co.za -> downloads -> software upgrades -> topaz
Setup:
Your terminal Server:
User logins for the terminal server cannot be duplicated.
User must be logged in only once on the terminal server.
TOPAZ:
TOPAZ must not be installed on the terminal server.
Setup in TOPAZ:
Enter the user for that extension.
Select your Call Monitor Pop-ups required.
Call Monitor:
Install Call Monitor on the terminal server.
Share the folder with Call Monitor on the network.
Setup in Call Monitor:
TOPAZ host name
TOPAZ port number (default: 25000)
Enter the extension
Enter the port number for that extension, it must be unique.
Each user on the terminal server must have there own port number.
Testing:
Use the Call Monitor inter-office messaging to test if you have
communication with TOPAZ.
[Call Monitor -> Configure -> Load Users], this will give you a list
of all the users from TOPAZ, which is setup for Call Monitor use.
Send a message to test if the network is and Call Monitor port
number setup is correct for each user.
[Call Monitor -> Messages -> Send Message]
Make a test call, while tracing the data from:
PABX3 -> VT100
PABX3 -> Call Data
TOPAZ -> SETUP -> TRANSACTION DATA
Once the call is ended, the call data string will be received
from the PABX and you can trace it from VT100 to TOPAZ. If the
call is updated in TOPAZ, you should also get your Call Monitor
pop-up.
