What is new in PABX3 version 3.3.3.4?
Postby Belinda Frick » Tue Nov 30, 2010 10:39 am
New Features :
On the file input screen you can now use wildcards to specify a group of filenames.
[e.g. C:\File*.txt or *.DAT or File.*]
Issues resolved
If data is received via the network, it will reset the timeout excatly like when
data is received via the serial port.
When a TCP connection was used and the options screen was saved, PABX3 would hang.
