TOPAZ report: Panasonic and the auto-attentant
Postby Belinda Frick » Tue Nov 30, 2010 10:48 am
The Panasonic has 2 ways to setup the auto-attentant. This will
influence the way we analise the output.
  • Option1:
    Incoming calls go direct to the Auto Attendant.
    The caller will have the option of entering the extension number
    they wish to be transferred to from their phone.
    The call gets transferred out to the extension.
    If the caller does not enter an extension number and waits
    it will get transferred to the swithboard.
  • Option2:
    The incoming call goes directly to the switchboard.
    The switchboard rings and if unanswered goes to the auto attendant.
    If the call is still unanswered it goes back to the switchboard.
    This process gets repeated until the call is answered.
    Analising the call data:
    To analyse the call data you need to group:
    your switchboard to the extensions
    the auto-attentants to the extensions
    the remaining extensions to the correct auto attentant option.
    You need to choose whether to link the swithboard or auto attendant as a branch
    department or section.
    also see: How do I setup a user in TOPAZ?
    Setting up the TOPAZ reports:
    Unanswered calls:
    Report for Incoming Unanswered calls per User/Ext :
    Report Options: Tick Summary & Incoming Calls only
    Select Records: ALL
    Summary Report Format: 6.Detail with Summary
    Order by: Group
    Maksimum Records: 0
    Field Selection: Action, like, %UNAN%
    Select the branch, department, and section to reflect the :
    The company
    Switchboard
    Auto Attendant
    Auto Attendant group
    Report of Ringtimes for Unanswered calls per User:
    To see the ringtime for unanswered calls change the
    Summary Report Format to 5.Total vs Average Ringtime
    Reports for the switchboard activity:
    Group by: Action
    Field Selection: Ext, =, now enter the switch board extension(normally 9).
    This will give a summary report per action with ringtime.
    To get a detailed report per action type enter a section for the switchboard
    under [DATA -> EXTENSION] Section, example SWITCHBOARD. Do a Update TRX.
    Now select the Section you created for the Switchboard under Only Select These and
    under Summary Report Format: 6.Detail with Summary.
    This will give you a detailed report for the Switchboard only.
    Also See: No unanswered calls on Panasonic PBXs
    All calls for the day grouped by User:
    Report Options: Tick Summary & Include Incoming Calls
    Select Records: Today
    Order by: When/detail only
    Maksimum Records: 0
    Group by: User
    Field Selection: (Leave Blank)
    Select All branches,All departments, and All sections.
    Please note: If you use the setting group by user, only the extensions/accounts
    linked to the user will show on the report. If you use the setting group by extension
    the report will show all users linked to that extension.
