This PABX3 supports wildcards for the filename. It will
process all files matching the wildcard specified.
Required:
PABX3, version 3.3.3.4
Setup: PABX3:
Under "COMMUNICATION"
tick "OffLine".
"Timeout" must be set to 0
OPTIONS -> INPUT FILE
Tick "Enable"
Next to "File Name", click on the yellow folder to browse.
Select one of your input files.
Now edit the file name.
Example: Change "Record.20050907131603" to "Record.20*".
Change the "Interval" value to when the file must be uploaded,
for example ever 15 minutes.
Click on "Save".
Conclude:
Once the file is read in by PABX3, it is moved to the folder,
"C:\Program Files\Datatex\pabx3\Rawdata".
The file is renamed to for example, "20051115_170418.txt".
The file name is made up of the date and the time that the file
was renamed and moved. The modify date will stay that of the orginal
file.
