TOPAZ Report: Result blank
Postby Belinda Frick » Tue Nov 30, 2010 10:49 am
  • Make sure of your report settings. Save the settings and pull the report again.
  • If your report settings is correct and you still get no report data, try to pull the same information under "ENQUIRIES".
    Also see:I can view my calls in the ENQUIRIES, but my report is blank.
  • If you see the report data here:
  • If you cannot find the data with an ENQUIRY:
    Check in the log files if the pip files were imported for the time period of your report.
    C:\Program Files\datatex\Topaz\OldPabxPip
    Sort listing by modify date to check date-time period for *.pip files.
    If no pip file was loaded the PABX3 was most likely closed and could not record the call data.
    If PABX3 was set to write the rawdata file, a file for each week of the year is created in
    "C:\Program Files\Datatex\PABX3\Rawdata".
    If this file is present you can import it via PABX3.
    See forum post: How do Import rawdata into TOPAZ
  • Do the following:
    • Close TOPAZ.
    • Delete "C:/tmptopaz" folder"
    • Open TOPAZ.
    • Pull the report again.
