Ericsson BP250: No data in PABX3, there is data in VT100
Postby Belinda Frick » Tue Nov 30, 2010 11:02 am
Ericsson BP250
Check that the EolChar is set to 13. PABX3 -> options -> communications (In some
instances with the BP250, the EolChar must be changed from 10 to 13.
Disable the time stamp facility on the buffer. When the time stamp facility is
enabled it adds the date at the beginning of the call data string, this prevents it
from going into PABX3.
Disable number sequencing on the buffer, PABX3 -> TOOLS -> VT100
type in SQ 0.
Check your Windows settings. It must be set to ENGLISH SOUTH-AFRICA.
Also See: Field "Maan" not found or error in updating rawdata
Make sure you are using the correct plugin.
Also See: No rawdata.txt file is created.
