TOPAZ rates update - S.A. : Orion cell router (06-02-2006)
Postby Belinda Frick » Tue Nov 30, 2010 11:06 am
New rates added:
A rate has been added for Orion cellular calls.
This needs to be setup in the routing table for the line your
PREMI-CELL is on. The default rate is costed at Telkom less 35%.
If you have a different package, you can modify this rate. Please
see How do I change an existing cellrouter rate?,
to modify the rate code CELLROUTORION.
Example of routing table: ORION Premi-cell for Cellular calls:
RatePrefix Line UsePrefix Description
1 CELLROUTORION ORION Premi-Cell
In this example all calls via line 1 will be costed at orion cellular
rate.
