The rate must already exist! You can modify the costing attached
to the rate code. This will have a time period and costing for
that time period. This Time Table is listed under "Description"
on the left bottom hand side of the screen.
Steps to follow:
In TOPAZ go to Rates -> rates
Navigate to the rate you want to change.
This must be displayed at the left hand top corner next to "Rate Code".
Click on the '+'(right-hand bottom corner) to insert a new record.
Click on the 'tick' to save the blank record.
Click on the 'Time Table' drop down to select the new Time table.
Your new time table will be added to the blank field.
Click on the 'tick' to save the changes.
