TOPAZ and the Philip Sopho 3000
Postby Belinda Frick » Tue Nov 30, 2010 11:16 am
Updated release: 20090827
Trunk numbers showed in the extension field. This was because of
PSTN to tie line/tie line to tie line and tie line to PSTN calls
and/or operator assistance.
To explaine: Below is a 'ruler' to show the position each
field starts at. The extension, line and number is placed
in different field depending on the type of call made
(as explained above):
         1         2         3         4         5         6         7         8         9
1234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
                  [PartyA    ][PartyAID          ][PartyB    ][PartyBID  ]        AB
        [Additional NR      ]
A = Party A Type (1 = extension, 2 = operator assistance, 3 = PSTN line, 4 = tie line, 5 = paging)
B = Party B Type (1 = extension, 2 = operator assistance, 3 = PSTN line, 4 = tie line, 5 = paging)
Translation per type A & B:
PSTN Line to Operator assistance
* #0160109082613100101062     0023321740458       8990                            32010000100124000000
      Ext := PartyB
      Number := PartyAID
      Line := PartyA
PSTN Line to tie line
* #0142109082612590101066     0832679939          0200102     7232                34010000001531000000
* #014327232                0000               000000000000
      Ext := PartyBID
      Number := PartyAID
      Line := PartyA
tie line to PSTN Line
* #0123109082613400200101     8187                0161601                         43010000103731000004
* #012420827875918
      Ext := PartyAID
      Number := AdditionalNumber
      Line := PartyB
* #0125109082613410200103                         0200104     8523                44010000002631000000
* #012628523                0000               000000000000
      Ext := AdditionalNumber
      Number := PartyA
      Line := PartyB
Updated release: 20090825
On Position 32 on the 2nd line of each call string, it identifies if
an account code or pin code is display from position 33. If '1' then it
is an account code, if '5' it is a pin code (PID code).
In TOPAZ only the Pin Code will be available under DATA -> ACCOUNTS.
In TNG you can link the User name to the Pin Code and a description
to the Account code. The Pin Code is only visible under
'User Configuration'.
History:
Requirements:
The PABX ouput must be set to SMDR, not faults ticketing.
Processor P805 or P810.
Plugin: PPhillips_Sopho_IS3000.dll,version "2005.10.6.2" or newer.
SMDR data for the Phillips Sopho 3000:
         1         2         3         4         5         6         7         8         9
Sample of output data:
                  [PartyA     ]
        YYMMDDHHMM        ssssss
* #019010602201418413434                          0101009                         13140000102431000166
* #019123721028             0005200601      000000000000166
* #019210602201420413438                          0101007                         13140000102531000058
* #019320739719635          0005660719      000000000000058
* #019410602201420413409                          0121203                         13140000100131000128
* #019510602201423413433                          0101003                         13140000000331000000
* #019629771172             0005319256      000000000000000
* #019710602201424413433                          0101005                         13140000000231000000
* #019829771172             0005319256      000000000000000
* #019910602201421413438                          0101011                         13140000103231000143
* #010029771172             0005660719      000000000000143
YYMMDD = Date
HHMM   = Time
ssssss = Duration
