Available on:
- download and unrar:
- the TOPAZ CD (PABX3 -> PROFILES -> LIB) in the LIB folder under PROFILES and PABX3.
Use 'PSiemensHicom150compressed.dll' version 2005_3_2_2 or newer.
Requirements:
- Sample of output data:
- Code: Select all
DD.MM.YY=Date
hh:mm:ss=time
LN=Line
EXT=extension
RNGTM=Ringtime
HH:MM:SS=duration
ACCNT=Account
1 2 3 4 5 6 7 8 9 10 11
12345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
Date time Duration Account
DD.MM.YYhh:mm:ss LN EXT RNGTMHH:MM:SS[Number ] ACCNT
03.07.0315:47:03 1 10300:0400:04:07 1
03.07.0316:00:51 1 110 00:02:218414380 2841 0 1
03.07.0316:09:03 1 10800:0000:00:00 2 0 1
03.07.0316:10:31 1 108 00:01:130218592810 2682 0 1
03.07.0316:15:27 1 10200:0400:00:008414636 2303 0 1
03.07.0316:16:33 1 102 00:00:188414636 2303 0 1
03.07.0316:34:43 1 100 0
03.07.0316:35:10 1 10200:0700:00:19 1
03.07.0316:39:27 7 101 00:00:340827883202 2303 0 2
03.07.0316:53:15 8 109 00:00:320833035475 2474 0 2
03.07.0316:54:02 1 109 00:00:278401390 2474 0 1
26.02.0912:37:50 1 40200:2000:00:057850 1
26.02.0912:38:37 4 40200:0200:00:367850 1
26.02.0912:40:04 7 40500:0400:00:2727214137850 1
26.02.0912:43:42 3 404 01:27:127990 2 21 5
- Required: HIPATH Manager E program (Siemens software)
The PABX is configured with the HIPATH Manager E version 5 or newer (this software is backwards compatible):
If you can download the data of the PABX to PC, you can proceed to CALL CHARGES, OUTPUT FORMAT, under FORMAT OF CALL RECORDS leave all options open, except the ones listed below (please tick these):
Compressed
log incoming
call duration
on ringing
decimal format
Under PORT ASSIGNMENT for OUTPUT FORMAT set to V24 port.
Select V24 port 1(25 pin) or 2(9 pin).
