Third Party Application required:
wget
Search the internet for wget or
try the link 'http://www.gnu.org/software/wget/'.
The output is received from the PABX unit and then written on
the harddrive by WGET. This file is then imported in PABX3 and
updated to TOPAZ either live or as setup under
SETUP -> PROPERTIES -> PABX.
Since the data is captured and then written to the harddrive and
then imported to PABX3 (If using the file input setup PABX3
will only import according to the time interval specified),
there will be a delay in the update to PABX3 and therefore also to TOPAZ.
Install:
To capture the data from the 3COM PABX, please use WGET.
Please search the internet for 'wget' or try the link
'http://www.gnu.org/software/wget/'. The program and manual is
available on this site.
Set up a Task Scheduler entry to run the wget batch file every day.
Setup the schedule:
Start > Control Panel > Scheduled Task > Add Scheduled Task
and follow the wizard.
Next
Browse > Select the bat file (Die saved location)
Perform this task weekly
Select the time to perform the bat file instructions
User name and password of Windows user
Finish.
Sample batch file:
@echo off
C:
CD \
CD \NBX
del billing.txt y
wget http://10.12.200.20/htfs0/billing.txt?a ... X,2007,1,1
rename billing.txt* billing.txt
exit
The XXXXXXXX has to be replaced with the administrators passwords and the ip address has to
change to the nbx’s ip address.
WGET will write out a file, which PABX3 can import.
Use the PABX3 input file option.
ALSO SEE: Setting up file input on the pabx3
Some information regarding the 3COM:
It keeps 30 days of information, each time you 'get' the
file it downloads the entire 30 days. Keep in mind the space that
it will require and that it is not 'live' data.
The plugin is for Version 5. The Version 6 is by default in XTML
format. However it can be set to use the 'old' route and give you
the same "billing.txt" file.
