When do I get a red circle around the PABX3 icon?
Postby Belinda Frick » Tue Nov 30, 2010 11:23 am
The red circle is displayed if no connection is made for by default an hour.
Settings:
  • If PABX3 has not received data via the comport for 1 hour it will display a red circle around the PABX3 icon.
    You can change this setting in:
    [PABX3 -> COMMUNICATIONS -> TIMEOUT]
    default time is 60 minutes.
  • If you are using TCP listen, then you will not be connecting to receive data, therefore after an hour you will get a red circle around the PABX3.
  • To stop PABX3 from displaying the red circle around the PABX3 icon:
    set the time to zero minutes.
  • You need to use PABX3 3.3.3.9, ALSO SEE What is new in PABX3 3.3.3.9?
