PABX3 Plugin:Phillips NEC IPC100 software 7.0H release 5.0.1
Postby Belinda Frick » Tue Nov 30, 2010 11:25 am
Release: 2013.10.08.1
    The plugin was written for date format mm/dd. It has been found that with recent releases the date format cannot be changed. We update the plugin so that you can select which date format - the default 'mm/dd' or 'dd/mm'.
    To use 'dd/mm' please use this update: download and unrar:
    NEC_IPC100_S7.0H_R5.0.1-release-2013_10_08_2.rar
    The rar file contains the plugin and the 'ddmm.dateformat' file fo rthe dateformat fof 'dd/mm'.
    To unrar the file you need wrar,7-zip, etc:
    Upload the dll file: How to update a Plugin
    Save both files in the plugins folder:
    C:\Program Files\Datatex\tng\plugins
    Log into TNG and select the plugin - check the version number, it must be 2013.10.08.2:
History:
    Release: 2009.09.01.1 Not release yet!
    The pin code value starts on position 72. It was previously taken from position 70, which caused a leading zero. This will cause a '0' pin code and TNG will display 'PLEASE ADD USER'.
    PNEC_IPC100_S70H_R501.rar
    • Unrar attachment.
    • Save in the TNG plugins folder: C:\Program Files\datatex\tng\plugins
      If you have a 64-bit PC, use the 64-bit program files folder and thereafter 'datatex\tng\plugins'.
      NOTE: If you are updating the plugin first stop the TNG service, copy the dll in the plugins folder and then start the service.
    Release: 2009.03.16.1 Not release yet!
    It has been noted that no pin code was used, a zero was present
    in the rawdata under the account code column. This caused problems
    in TNG as it displayed 'Please add user' because no user was allocated
    to pin '0'. The '0' has been removed and the pin code field will have
    no value.
    Release: 2009.01.23.1 Not release yet!
    It has been noted that the extension and line/trunk number has trailing space.
    This caused the description name in TNG not to be added. The spaces has
    been removed.
    Requirements:
    • This plugin was written for sortware 7.0H release 5.0.1
    • PABX format:
      • Use quick install for South-Africa
      • This will use the SMDR output 'format 2'
        SMDR Date Format must be set to 'American'
        OR set the Programming mode: 35-02-14=01
      • 'Minimum' and 'maksimum digits' is left at default, which is zero
      • Extension must be 'number' output, not name
    • Plugin: 'PNEC_IPC100_S70H_R501.dll', version '2006.7.26.1' or newer.
    • SMDR data for Phillips NEC IPC100 sortware 7.0H release 5.0.1:
               1         2         3         4         5         6         7         8
      12345678901234567890123456789012345678901234567890123456789012345678901234567890
      Sample of output data:
                                                               06132006 PAGE 002
         CLASS  TIME DATE  LINE DURATION  STATION   DIALLED No.CLI  RDCOST ACCOUNT
      47 POT   13:30 06/13 001  00:00:03 4000       5094512                0
      48 POT   13:30 06/13 003  00:00:00 4002       0834591829             0
      49 POT   13:30 06/13 001  00:00:00 4000       5094515                0
      50 POT   13:35 06/13 002  00:00:06 4000       0724407322             0
      51 PIN   13:39 06/13 001  00:00:05 4000                        0:07
      52 PIN   13:40 06/13 001  00:00:13 4000                        0:09
      53 POT   13:43 06/13 001  00:00:00 4002                              0
      54 BRD   13:43 06/13 002  00:00:00 4002                              0
      55 BRD   13:44 06/13 003  00:00:00 4000                              0
Re: PABX3 Plugin:Phillips NEC IPC100 software 7.0H release 5
Postby Belinda Frick » Wed Sep 10, 2014 9:04 am
Find attached Linux version of the plugin:
PNEC_IPC100_S70H_R501-version_2013-10-08-02 .rar
Unrar the file (no password).
For TNG, please save in the folder \opt\datatex\tng\plugins.
To select see forum post:
How do I select a different plugin in TNG?
Postby roland » Fri Sep 12, 2014 10:00 am
Thanks! Much appreciated!
roland
