Does DTP write out a rawdata file?
Postby Belinda Frick » Tue Nov 30, 2010 11:38 am
No DTP does not write out rawdata.
It creates the pabx.pip file in the file path specified under 'Configure' in the 'TOPAZ'
section for 'Pip File'.
TOPAZ is configured to read this file under 'SETUP', 'PROPERTIES', 'PABX' and 'PABX File Update'.
When the pip file is read in by TOPAZ, it is renamed and moved to the folder:
'C:\Program Files\Datatex\Topaz\OldPabxpip'. You can sort this file by modify date to
get the latest file moved.
Under 'SETUP', 'PROPERTIES', 'PABX' and 'Run every... minutes' it show every how many minutes it
is moved to oldpabxpip. This will give you an idea of how many files per day is loaded into TOPAZ.
