How to load rawdata manually into PABX3?
Postby Belinda Frick » Tue Nov 30, 2010 11:43 am
Check that you are using the correct plugin
profiles\lib\PanasonicTDA.dll
Go TO PABX3 - TOOLS - load raw data.
Select the folder from where you want to load data and open.
