Error:When opening qrp report
Postby Belinda Frick » Wed Dec 01, 2010 7:02 am
OVERVEIW
The Meta file error occurs when you are trying to open a file with a different version of
the software that it was created with. According to the internet (QV being a shareware application)
you need to make sure that you are opening the report with the same version of the software with
which it was created.
Try these steps
1. Copy QV to the same location where the report was saved to,
2. Open QV and select the report from there,
3. Double click on the report to open it.
