PABX3 Plugin: NEC Aspire Version 6 Release 0
Postby Belinda Frick » Wed Dec 01, 2010 7:15 am
Update: 20100225
    Download and unrar:
    PNEC_Aspire_v6r0-version2010_05_03_1.rar
    Upload the dll file: How to update a Plugin
    The following action is now catered for:
    ITRS - Incoming Transfer
History:
Updated: 20100216
    IVOW - ISDN Outgoing Call with a pin code
Updated: 20080606
    Download and unrar:
    PNEC_Aspire_v6r0-version2008_06_06_1.rar
    The plugin now also caters for the format where the date is included, see sample data below:
       CLASS  TIME DATE  LINE DURATION  STATION   DIALLED No./CLI  RD/COST ACCOUNT
    01 POT   07:29 29/11 002  00:00:00 202        1                        359
    02 POT   07:33 29/11 001  00:00:23 204        0217994490
    03 PIN   08:06 29/11 001  00:01:20 200                         0:14
    04 PIN   08:13 29/11 002  00:00:33 204                         0:07
    05 POT   08:29 29/11 002  00:00:00 201        0                        0914
    06 POT   08:29 29/11 001  00:00:00 201
    07 POT   08:30 29/11 002  00:00:18 201        0215923044               0914
    08 POT   08:30 29/11 001  00:00:00 201
    09 POT   08:31 29/11 002  00:00:00 201        0215924033               0914
    10 POT   08:31 29/11 001  00:00:00 201
    11 POT   08:33 29/11 002  00:00:00 201
    12 POT   08:33 29/11 001  00:00:00 201
    13 POT   08:34 29/11 001  00:00:00 201
    14 POT   08:34 29/11 002  00:00:00 201        0215924033               0914
    15 POT   08:34 29/11 001  00:02:17 201        0215310914               0914
    16 POT   08:37 29/11 002  00:03:35 201        0861114351               0914
Released: 8 March 2007
  • This plugin was written for
    the NEC Aspire
    using system software version 6 and release 0
  • See sample of rawdata below for output format.
  • Please use plugin, 'PNEC_Aspire_v6r0'. Version '2007.5.8.1' or newer.
  • Available:
    On the TOPAZ CD (version 1.7.7.1 or newer) in the folder PABX3 -> PROFILES -> LIB.
    The PNEC_Aspire_v6r0.dll needs to be copied to
    TOPAZ: C:\Program Files\Datatex\Pabx3\Profiles\Lib.
    TNG: C:\Program Files\Datatex\tng\plugins
  • Sample of rawdata
        04/11/2007 PAGE 151
       CLASS  TIME    LINE    DURATION  STATION   DIALLED No./CLI  RD/COST ACCOUNT
    01 PIN   07:27 006                                             0:33    NO ANSWER
    02 PIN   07:35 006                                             0:33    NO ANSWER
    03 POTW  07:57 013        00:01:49 256        0849044629             0 W/042
    04 PIN   08:04 003                                             0:32    NO ANSWER
    05 PIN   08:06 003        00:01:09 500                         0:27
    06 PIN   08:06 001        00:01:09 500                         0:26
    07 PIN   08:07 002                                             0:33    NO ANSWER
    08 POTW  08:04 004        00:03:15 254        0229212831             0 W/031
    09 PIN   08:08 004                                             0:33    NO ANSWER
    10 PIN   08:09 001                                             0:20    NO ANSWER
    11 POTW  08:08 006        00:01:17 256        0214135856             0 W/042
    12 PIN   08:09 002        00:00:57 200                         0:06
    13 PIN   08:10 006        00:00:20 200                         0:05
    14 PIN   08:10 003        00:00:19 200                         0:17
    15 PTRS  08:11 003        00:00:22 272                         0:17
    16 PIN   08:11 004        00:00:09 200                         0:05
  • The plugin:
    • Please Note:
      The above format does not have a date for each call record and therefore the PC date will be used.
      The time of the call is the start time of the call.
      Only incoming calls has a ringtime.
      Calls with class BRD and ALB will be disgarded.
      Outgoing calls with a zero duration will be marked as outgoing unanswered.
      Incoming calls with 'NO ANSWER' in the 'Account' column will be marked as incoming unanswered.
      Incoming calls with a zero duration will be marked as incoming unanswered.
    • Action codes:
      This plugin only has action codes for:
      answered
      unanswered
      transferred
      Class definition (posision 4 to 7 in rawdata):
      POT - Outgoing trunk call
      POTW - Outgoing trunk call placed using Toll Restriction Override
      POTA - Outgoing trunk call placed using Toll Restriction Override
      PIN - Incoming trunk calls
      ALB - All lines in group are busy(group number follows TIME field)
      BRD - Call blocked due to Toll Restriction
      PTRS - Transferred call
      IVIN - Incoming ISDN trunk call
      IVOT - Outgoing ISDN trunk call
      IVOTW - ISDN Outgoing trunk call placed using Toll RestrictionOverride
      ITRS - ISDN transferred call
