See sample of rawdata below for output format.
Please use plugin, 'PSiemens3750.dll'. Version '2006.1.30.6' or newer.
Available:
- Download and unrar: How to update a Plugin
- On the TOPAZ CD (version 1.7.7.1 or newer) in the folder PABX3 -> PROFILES -> LIB.
The PSiemens3750.dll needs to be copied to- TNG:
C:\Program Files\Datatex\tng\plugins. - TOPAZ:
C:\Program Files\Datatex\Pabx3\Profiles\Lib.
- TNG:
Sample of rawdata:
- Code: Select all
1 2 3 4 5 6 7 8 9 10 11 12 13
1234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
a
a=action code(incoming=1,3,5,7 and outgoing=2,4,6,8,9)
DATE TIME EXT RTIMEDUR NUM ACC CODE
19.01.0418:07:04 1 8458 00:00:044338499 21000 0 1
19.01.0418:08:37 1 8458 00:00:174338499 21000 0 1
23.02.0415:12:48 5 849000:0100:00:150224332182 1
23.02.0415:13:22 3 8446 00:02:280123108363 369 0 1
23.02.0415:13:24 1 8457 00:07:280215727002 26542 0 1
23.02.0415:14:05 5 8458 00:01:160224332182 35
23.02.0415:14:21 4 843100:1400:00:550224332011 1
27.04.1023:57:03 1 020400:0100:01:120722108702 1
27.04.1023:57:16 2 020700:0100:02:260722129513 1
27.04.1023:57:37 31 0110 00:00:340783823884 2 6 1
27.04.1023:58:40 32 0110 00:00:090722615333 2 6 1
27.04.1023:59:28 3 020500:0100:00:270722192879 1
27.04.1023:59:31 3 020800:0100:00:010722257316 1
27.04.1023:59:47 3 020100:0100:00:000728805798 1
27.04.1023:59:58 3 020900:0100:00:010728886457 1
28.04.1000:00:01 2 020200:0100:01:490722298811 1
Action codes:
- This plugin only has action codes for:
answered
unanswered
internal
Also see: What is the pinouts for the Siemens 3750?
