PABX3 plugin: Lucent Index
Postby Belinda Frick » Wed Dec 01, 2010 7:17 am
Updated: 20080926
Corrected:
When the PABX is CLI enabled, the call direction is incorrect.
The telephone number contained non-numberic characters, for example '#'.
History:
This plugin was written for Lucent Index.
See sample of rawdata below for output format.
Please use plugin, 'PLucentIndex.dll'. Version '2007.5.10.1' or newer.
Available:
On the internet, www.datatex.co.za -> Support -> logon -> topaz -> downloads -> siemens.
The 'plg-lucent_index-update-2007_5_10_1.exe'
will extract the dll file in the lib folder.
On the TOPAZ CD (version 1.7.7.1 or newer) in the folder PABX3 -> PROFILES -> LIB.
The PSiemens3750.dll needs to be copied to C:\Program Files\Datatex\Pabx3\Profiles\Lib.
Sample of rawdata:
1 2 3 4 5 6 7 8 9 10
1234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
19:27:59 0:30 6556 734 00824539848 01
19:32:18 0:45 6556 738 00824539848 01
19:34:48 00:13 0:45 322 718 009447786027616 01
19:36:43 1:43 307 737 00765057245 01
19:38:04 0:38 304 739 00825409559 01
19:38:32 00:14 0:33 322 719 00933562718080 01
19:39:42 00:03 0:00 521 700 I/C NOT ANSWERED
19:39:15 00:19 1:28 322 720 00933680184835 01
19:40:39 1:05 307 734 00724572382 01
19:42:14 0:18 307 738 00724572382 01
Action codes:
This plugin only has action codes for:
answered
unanswered
transferred
