PABX3 Plugin: Meridian BCM version 3.7 release2.4f
Postby Belinda Frick » Wed Dec 01, 2010 7:18 am
Update Released: 15 May 2007
    Changes made:
    The PMeridian_BCM_ver3_7_release2_4f.dll plugin does not correctly process outgoing calls made
    using *31* (hides callers id). The update will now check for '*' on the first position and for
    numeric on the second position to identifiy a valid telephone number.
    Download and Unrar:
    PMeridian_BCM_ver3_7_release2_4f-version_2007_05_15.rar
    Upload the dll file: How to update a Plugin
History:
  • This plugin was written for Meridian BCM.
  • See sample of rawdata below for output format.
  • Please use plugin, 'PMeridian_BCM_ver3_7_release2_4f.dll'. Version '2007.5.15.2' or newer.
  • Available:
    On the TOPAZ CD (version 1.7.7.1 or newer) in the folder PABX3 -> PROFILES -> LIB.
    The PMeridian_BCM_ver3_7_release2_4f.dll needs to be copied to
    C:\Program Files\Datatex\Pabx3\Profiles\Lib.
Sample of rawdata:
         1         2         3         4         5         6         7         8         9        10
1234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
--------   04/25/07   12:10:02   LINE = 0072   STN = 232
00:00:00   OUTGOING CALL
           DIGITS DIALED    0214480181
00:00:16   CALL RELEASED
--------   04/25/07   12:11:03   LINE = 0269   STN = 232
00:00:00   INCOMING CALL    RINGING 0:18
           LINE = 0001
00:00:39   CALL RELEASED
--------   04/25/07   12:12:11   LINE = 0269   STN = 232
00:00:00   INCOMING CALL    RINGING 0:06
           LINE = 0005
00:00:17   CALL RELEASED
--------   04/25/07   12:10:19   LINE = 0071   STN = 241
           DIGITS DIALED    0215106503
00:02:13   CALL RELEASED
--------   04/25/07   12:15:53   LINE = 0071   STN = 226
           DIGITS DIALED    021
00:00:02   CALL RELEASED
--------   04/25/07   12:15:56   LINE = 0071   STN = 226
           DIGITS DIALED    0314808600
00:00:46   CALL RELEASED
--------   04/25/07   12:12:47   LINE = 0072   STN = 241
           DIGITS DIALED    0215554495
00:04:19   CALL RELEASED
--------   04/25/07   12:05:44   LINE = 0070   STN = 246
00:00:07   HOLD
00:00:07   UNHOLD
           DIGITS DIALED    0115712351
00:11:23   CALL RELEASED
--------   04/25/07   12:18:04   LINE = 0072   STN = 246
00:00:01   HOLD
00:00:01   UNHOLD
00:00:12   CALL RELEASED
--------   04/25/07   12:10:33   LINE = 0264   STN = 230
00:00:00   INCOMING CALL    RINGING 0:03
           LINE = 0007
00:07:58   CALL RELEASED
--------   04/25/07   12:07:11   LINE = 0069   STN = 239
00:00:04   HOLD
00:00:04   UNHOLD
           DIGITS DIALED    *31*0219002113#
00:12:25   CALL RELEASED
--------   08/29/05   11:11:14   LINE = 0060   STN = 2116
           BC = SPEECH
           VOIP CALL
           DIGITS DIALED    0117995600
00:00:50   CALL RELEASED
--------   08/29/05   11:12:06   LINE = 0060   STN = 2116
           BC = SPEECH
           VOIP CALL
           DIGITS DIALED    0829038084
00:01:07   CALL RELEASED
--------   08/29/05   11:13:19   LINE = 0060   STN = 2116
           BC = SPEECH
           VOIP CALL
00:01:15   CALL RELEASED
Action codes:
    This plugin only has action codes for:
    answered
    unanswered
    transferred
