PABX3 PLUGIN: NEC 96i Revision 2
Postby Belinda Frick » Wed Dec 01, 2010 7:32 am
NOTE: This PABX does not send off a date as part of the call details. The PC date will be used. This means the call date will register as date of the PC at the time the calls are loaded into TNG.
Update released: 2011.09.19.1
The pin codes has trailing spaces or only lists a blank value. This caused pin codes not to be linked to user names in TNG. It will show 'PLEASE ADD USER' in the user field.
PNEC_96i_Rev2-201109191-password.rar
Steps to update plugin:
  • Unrar file, password is datatex.
  • Copy over existing PNEC_96i_Rev2.dll in the folder:
    for TNG: 'C:\Program Files\datatex\tng\plugins'.
    For TOPAZ: 'C:\Program Files\datatex\pabx3\profiles\lib\'.
  • Confirm verison number shows '2011.09.19.1':
    For TNG check under General Settings next to Version.
    For TOPAZ, check in PABX3 on the information line at the bottom of the PABX3 screen next to PLUGIN:.
History:
This plugin was written for NEC 96i PABX.
See sample of rawdata below for output format.
Please use plugin, 'PNEC_96i_Rev2.dll'. Version '2007.5.15.2' or newer.
Available:
On the TOPAZ CD (version 1.7.7.1 or newer) in the folder PABX3 -> PROFILES -> LIB.
The PNEC_96i_Rev2.dll needs to be copied to C:\Program Files\Datatex\Pabx3\Profiles\Lib.
Sample of rawdata:
         1         2         3         4         5         6         7         8         9        10
123456789012345678901234567890123456789012345678901234567890123456789012
   CLASS  TIME    LINE    DURATION  STATION   DIALLED No./CLI  RD/COST ACCOUNT
01 ITRS  11:35 ISDN       00:00:34 5424                        0:05
02 IVIN  11:28 ISDN       00:08:31 5440                        0:03
03 POT   11:36 VODA       00:00:41 5438       0829087638             0
04 ALB   11:37 02         00:01:04
05 IVOT  11:34 ISDN       00:02:38 5402       0123173000             0
06 IVIN  11:36 ISDN       00:00:44 5447                        0:03
                                                            21/11/2011 PAGE 001
01 POT   15:07 001        00:00:13 200        0215310914             0
02 POT   15:08 001        00:00:00 200        1026                   0
03 PIN   15:09 001                                             0:27    NO ANSWER
04 POT   15:10 001        00:00:00 200                               0
05 POT   15:10 001        00:00:06 200        0215301691             0
06 PTRS  15:11 001        00:00:09 201        0215301691             0
07 POT   15:11 001        00:00:00 200                               0
08 PIN   15:12 001        00:00:10 200                         0:02
09 PTRS  15:12 001        00:00:09 201                         0:02
10 POT   15:16 001        00:00:00 200        0215301691             0
11 POT   15:17 001        00:00:00 200        0215301691*1           0
Action codes:
This plugin only has action codes for:
answered
unanswered
transferred
Class definition (posision 4 to 7 in rawdata):
POT - Outgoing answered
VOT - Outgoing answered
OTW - Outgoing answered
TRS - transferred calls (Incoming or Outgoing)
PIN - Incoming unanswered
VIN - Incoming answered
