Which plugin do I use for the Ericsson MX one PABX?
Postby Belinda Frick » Wed Dec 01, 2010 7:33 am
PABX3 Plugin for the Ericsson MD110 version 2006.08.16.0 or newer
Available:
On the internet, www.datatex.co.za -> login -> topaz -> downloads -> ericsson.
The 'plg-ericssonmd110_format4_2-update-2006_8_16_0.exe'
will extract the dll file in the lib folder.
On the TOPAZ CD (version 1.7.7.1 or newer) in the folder PABX3 -> PROFILES -> LIB.
The PEricssonMD110_Format4_2.dll needs to be copied
to C:\Program Files\Datatex\Pabx3\Profiles\Lib.
