PABX3 TOPAZ Plugin: Opera Flexicom Network
Postby Belinda Frick » Wed Dec 01, 2010 7:39 am
This plugin was written for Opera Flexicom Network.
See sample of rawdata below for output format.
Please use plugin, 'POpera_412_Network.dll'. Version '2004.11.29.4' or newer.
Available:
On the TOPAZ CD (version 1.7.7.1 or newer) in the folder PABX3 -> PROFILES -> LIB.
The 'plg-opera_flexicom_network.dll-update-2004_11_29_4.exe' will extract the dll file in the lib folder.
The POpera_Flexicom_Network.dll needs to be copied to C:\Program Files\Datatex\Pabx3\Profiles\Lib.
This pabx gives off the rawdata as comma delimited, see below field names used in our plugin:
,date,time,line,ext,,Incoming/Outgoing,,,duration,ringtime,number,tmpnumber,,,pincode,
Sample of rawdata:
  480,15/08/07,10:25:06,             Line 01,                  11,               Karin,I,Y, ,00:00:14,00:03,          0314609000,                    ,                    ,      Operator Group,        ,  ,
  480,15/08/07,10:25:23,             Line 01,                  12,            Leighann,T,Y, ,00:15:03,00:00,          0314609000,                    ,                    ,      Operator Group,        ,  ,
  492,15/08/07,10:40:49,             Line 03,                  20,               Msizi,O,N, ,00:00:00,01:09,           NO NUMBER,                    ,          0313087981,                    ,        ,  ,
  493,15/08/07,10:42:12,             Line 01,                  11,               Karin,I,Y, ,00:00:16,00:03,             UNKNOWN,                    ,                    ,      Operator Group,        ,  ,
Please note:
If 'number' is blank, then 'tmpnumber' will be used.
If 'tmpnumber' has no value the number is displayed as INCOMING/OUTGOING/TRANSFER.
This plugin only has action codes for:
answered
unanswered
transferred (answered and unaswered)
