Released: not released yet!
Requirements:
PABX format: See output sample format below.
PABX Software Version: 4.2
Plugin: 'PUCServer_v4_2.dll', version '2007.10.25.1' or newer.
Available:
On the internet, www.datatex.co.za ->
support -> login -> topaz -> downloads -> ucserver.
The plg-PUCServer_v4_2-update-2007_10_25_1.exe
will extract the dll file in the lib folder.
On the TOPAZ CD in the folder PABX3 -> PROFILES -> LIB.
The PUCServer_v4_2.dll needs to be copied
to C:\Program Files\Datatex\Pabx3\Profiles\Lib.
SMDR data for the UC Server:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
12345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
Sample of output data:
09/25/07 13:21:20 [10.0.2.5] (reserved2.info) Sep 25 13:26:45 Vega2 LOGGER : BILL:,0000000060,25/09/2007,13:08:19,25/09/2007,13:26:45,0,00:18:13,16,9901,0303,"from: TEL:218,DISP:Gavin Child,TA:10.0.2.3 to: NAME:0115311217,TEL:0115311217 dest: TEL:0115311217"
09/25/07 13:22:23 [10.0.2.4] (reserved2.info) Sep 26 12:28:22 Vega1 LOGGER : BILL:,0000000029,26/09/2007,12:26:48,26/09/2007,12:28:22,0,00:00:30,16,0302,9901,"from: TEL:0216837387 to: dest: TEL:5000"
09/25/07 13:23:10 [10.0.2.5] (reserved2.info) Sep 25 13:28:34 Vega2 LOGGER : BILL:,0000000070,25/09/2007,13:26:32,25/09/2007,13:28:34,0,00:01:57,16,9901,0302,"from: TEL:220,DISP:Iain Wilson,TA:10.0.2.3 to: NAME:0112365500,TEL:0112365500 dest: TEL:0112365500"
09/25/07 13:25:40 [10.0.2.5] (reserved2.info) Sep 25 13:31:05 Vega2 LOGGER : BILL:,0000000072,25/09/2007,13:27:55,25/09/2007,13:31:05,0,00:03:04,16,9901,0304,"from: TEL:205,DISP:Natalie,TA:10.0.2.3 to: NAME:0118489000,TEL:0118489000 dest: TEL:0118489000"
09/25/07 13:26:31 [10.0.2.5] (reserved2.info) Sep 25 13:31:56 Vega2 LOGGER : BILL:,0000000073,25/09/2007,13:28:01,25/09/2007,13:31:56,0,00:02:41,16,0303,9901,"from: TEL:0114959848 to: dest: TEL:5000"
09/25/07 13:26:41 [10.0.2.5] (reserved2.info) Sep 25 13:32:06 Vega2 LOGGER : BILL:,0000000075,25/09/2007,13:30:34,25/09/2007,13:32:06,0,00:01:19,16,9901,0302,"from: TEL:220,DISP:Iain Wilson,TA:10.0.2.3 to: NAME:0112800300,TEL:0112800300 dest: TEL:0112800300"
09/25/07 13:27:19 [10.0.2.5] (reserved2.info) Sep 25 13:32:44 Vega2 LOGGER : BILL:,0000000076,25/09/2007,13:32:05,25/09/2007,13:32:44,0,00:00:25,16,9901,0303,"from: TEL:219,DISP:Claire Watson,TA:10.0.2.3 to: NAME:0119369943,TEL:0119369943 dest: TEL:0119369943"
09/22/07 13:20:15 [10.0.2.4] (reserved2.info) Sep 23 12:26:24 Vega1 LOGGER : BILL:,0000000014,23/09/2007,12:24:42,23/09/2007,12:26:24,0,00:01:42,16,0303,9901,"from: TEL:0117067244 to: dest: TEL:5000"
09/22/07 13:25:50 [10.0.2.4] (reserved2.info) Sep 23 12:32:00 Vega1 LOGGER : BILL:,0000000015,23/09/2007,12:30:54,23/09/2007,12:32:00,0,00:01:06,16,0302,9901,"from: to: dest: TEL:5000"
09/22/07 13:27:49 [10.0.2.4] (reserved2.info) Sep 23 12:33:58 Vega1 LOGGER : BILL:,0000000016,23/09/2007,12:33:12,23/09/2007,12:33:58,0,00:00:05,16,0304,9901,"from: TEL:0117067244 to: dest: TEL:5000"
09/22/07 13:30:23 [10.0.2.4] (reserved2.info) Sep 23 12:36:33 Vega1 LOGGER : BILL:,0000000017,23/09/2007,12:35:54,23/09/2007,12:36:33,0,00:00:07,16,0301,9901,"from: TEL:0117067244 to: dest: TEL:5000"
09/22/07 13:57:34 [10.0.2.4] (reserved2.info) Sep 23 13:03:43 Vega1 LOGGER : BILL:,0000000018,23/09/2007,13:01:35,23/09/2007,13:03:43,0,00:00:07,16,0303,9901,"from: TEL:0117067244 to: dest: TEL:5000"
09/22/07 16:44:52 [10.0.2.4] (reserved2.info) Sep 23 15:51:01 Vega1 LOGGER : BILL:,0000000019,23/09/2007,15:49:48,23/09/2007,15:51:01,0,00:01:02,16,9901,0301,"from: TEL:902,DISP:Gert Cloete,TA:10.0.2.3 to: NAME:0164241020,TEL:0164241020 dest: TEL:0164241020"
09/22/07 20:35:41 [10.0.2.4] (reserved2.info) Sep 23 19:41:51 Vega1 LOGGER : BILL:,0000000020,23/09/2007,19:41:36,23/09/2007,19:41:51,0,00:00:14,16,0302,9901,"from: TEL:0823573660 to: dest: TEL:5000"
Please note:
This plugin is written for output format where the 5000 range is for
the auto attendant. The auto attendant is for incoming calls. Therefor
the 5000 range is to identify incoming calls.
When using the Syslog facility and then reading the data with the file
reader service, it must only be used for TMS purposes.
This facility is under no circumstances to be used with AMETHYST.
AMETHYST requires real-time SMDR data.
