Upload the dll file: How to update a Plugin
History:
Release date: Not released yet!
Please use the PSamsung_7400.dll, version 2007.11.9.1 or newer.
Requirements:
- PABX format: See output sample format below.
- Please select South-Africa when installing the PABX.
- Only has an IP connection option - No Serial.
- Plugin: 'PSamsung_7400.dll', version '2007.11.9.1' or newer.
Also available on the TOPAZ CD:- Navigate to PABX3 -> Profiles -> Lib. The PSamsung_7400.dll needs to be copied
For TOPAZ into C:\Program Files\Datatex\Pabx3\Profiles\Lib.
For the TNG software into C:\Program Files\Datatex\TNG\Plugins
SMDR data :- Code: Select all
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
12345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
Sample of output data:
1 8411 11/08 15:27:09 GROUP IN 5018:2411
1 8463 1935 7126 11/08 15:25:39 00:01:28 O 0761854208 0.00
1 2113 7019 11/08 15:27:04 00:00:10 IT 8469 0.00 0728720147
1 5018 7033 11/08 15:26:54 00:00:24 A 8469 0.00 0848309240
1 8403 7047 11/08 15:25:55 00:01:26 T 8469 0.00 0217020958
T EXT AUTH TRK MM/DD STT.TIME DURATION FG DIALED DIGIT ACCOUNT CODE MCNT COST CLIP NUMBER CLIP NAME
1 8438 7127 11/08 15:22:25 00:04:56 O 0834004947 0.00
1 5018 1359 7060 11/08 15:26:56 00:00:30 A 8469 0.00 0829038093
1 8465 7126 11/08 15:27:26 00:00:02 O 0823134823 0.00
1 8400 7057 11/08 15:27:27 00:00:00 O 1 0.00
1 8415 7037 11/08 15:26:34 00:01:00 T 8469 0.00
1 8401 7130 11/08 15:26:49 00:00:52 O 0737246609 0.00
1 8411 7019 11/08 15:27:15 00:00:28 T 8469 0.00 0728720147
1 2113 7031 11/08 15:27:15 00:00:30 IA 8469 PEP 0.00 0213932101
1 8480 7032 11/08 15:26:12 00:01:34 O 0538312617 0.00
1 8459 7036 11/08 15:24:58 00:02:49 T 8400 0.00 0785888063
NOTE:
- Pin Codes:
To pull user reports, we require a pin code in the rawdata. This pin code must be associated to a user name in the TMS to pull reports by user name.
Rawdata example of pin code call:- Code: Select all
In this example the pin code is 1935. It is displayed in the 'AUTH' column in the rawdata.
Test: Make a call using the pin code. Check the rawdata to see if the pin code is displayed in the AUTH column. If not, please contact your PABX support.
If you have a problem with historic data, just check the rawdata for that period and if any pin codes displayed under AUTH column. If any, check if the pin code is configured with a user.
