Which plugin do I use for the Alcatel 4200?
Postby Belinda Frick » Wed Dec 01, 2010 7:50 am
Overview
We cater for two formats of the Alcatel 4200, below are examples of them.
Requirements:
PABX format: See output sample format below.
Plugin: 'PAlcatel 4200.dll', version '2005.12.6.4' or newer.
Available: On the internet, www.datatex.co.za ->
support -> login -> topaz -> downloads -> Alcatel.
The plg-alcatel4200-update-2005_12_6_4.exe
will extract the dll file in the lib folder.
On the TOPAZ CD in the folder PABX3 -> PROFILES -> LIB.
The PAlcatel_4200.dll needs to be copied
to C:\Program Files\Datatex\Pabx3\Profiles\Lib.
Sample rawdata of the Alcatel 4200 when using the PAlcatel4200.dll
A206 <-T 9 29/07/03 12:50 00:02:55 0 ST .......................... M 00:18 0.00 ................ HASEENA.........
A205 --> 6 29/07/03 12:52 00:01:15 0 ST A5316112.................. M 00:00 0.00 ................ SAMANTHA........
A200 <-- 9 29/07/03 12:53 00:00:17 0 ST .......................... M 00:04 0.00 ................ SWITCHBOARD.....
A206 --> 7 29/07/03 12:53 00:00:16 0 ST A0116951600............... R 00:00 0.00 ................ HASEENA.........
A200 <-- 11 29/07/03 12:53 00:00:33 0 ST .......................... M 00:04 0.00 ................ SWITCHBOARD.....
A205 <-T 10 29/07/03 12:53 00:01:17 0 ST .......................... M 00:13 0.00 ................ SAMANTHA........
A206 --> 1 29/07/03 12:54 00:01:12 0 ST A0116951600............... R 00:00 0.00 ................ HASEENA.........
A206 <-T 11 29/07/03 12:55 00:00:22 0 ST .......................... M 00:11 0.00 ................ HASEENA.........
A217 <-T 10 29/07/03 12:55 00:01:08 0 ST .......................... M 00:07 0.00 ................ Spare...........
A202 --> 15 29/07/03 12:56 00:00:19 0 ST C0832847018............... M 00:00 0.00 ................ TIM.............
A205 --> 2 29/07/03 12:54 00:02:49 0 ST A8721727.................. M 00:00 0.00 ................ SAMANTHA........
A202 <-T 10 29/07/03 12:56 00:01:01 0 ST .......................... M 00:00 0.00 ................ TIM.............
A201 --> 1 29/07/03 12:57 00:00:06 0 ST A5527421.................. M 00:00 0.00 ................ Fax.............
Plugin: 'PAlcatel 4200b.dll', version '2005.1.13.1' or newer.
The plg-alcatel4200b-update-2005_1_13_1.exe
The PAlcatel_4200b.dll needs to be copied
Sample rawdata of the Alcatel 4200b when using the PAlcatel4200B.dll
A240 --> N04 03/06/02 09:25 00:00:19 0 ST I 0176380047................ ................ ALAN PAULL......
A200 <-- N04 03/06/02 09:25 00:01:05 0 ST X .......................... ................ JHB BRANCH......
A212 --> L03 03/06/02 09:23 00:00:00 0 ST 0829046587................ ................ REPS............
A264 --> L02 03/06/02 09:26 00:00:00 0 ST 0829046576................ ................ GATE............
A264 --> L03 03/06/02 09:27 00:00:00 0 ST 0829046576................ ................ GATE............
A297 <-- N04 03/06/02 09:27 00:00:53 0 ST X .......................... ................ VM 2............
A269 <-- N06 03/06/02 09:23 00:04:49 0 ST X .......................... ................ ANTHONY PARKER..
A235 --> N05 03/06/02 09:26 00:03:22 0 ST 0126734793................ ................ FAX [ACCOUNTS]..
A244 --> N07 03/06/02 09:28 00:00:35 0 ST I 1026...................... ................ ALLAN PEDDIE....
A215 <-- N00 03/06/02 09:17 00:12:17 0 ST .......................... ................ COMPUTER RM.....
A244 --> N01 03/06/02 09:29 00:00:46 0 ST I 1026...................... ................ ALLAN PEDDIE....
A297 <-- N07 03/06/02 09:33 00:00:22 0 ST .......................... ................ VM 2............
A269 --> N03 03/06/02 09:32 00:00:52 0 ST 0169861295................ ................ ANTHONY PARKER..
A222 <-- N01 03/06/02 09:32 00:01:33 0 ST .......................... ................ SWITCHBOARD.....
